Hydraulic Fan Assembly
Discussion in 'Wanted' started by SHU-DOG, May 10, 2013.
  1. SHU-DOG
    SHU-DOG Full Access Member
    816
    May 18, 2006
    Just Moved to Reno NV from Southrn Calfornia
    I may need the hydraulic fan assembly.
    If anyone has upgraded and still has their OEM one I may be interested.
    Ill find out this weekend after more investigating.
    Got a slight vibration started after putting in new radiator.....my fan has some nicks on it.
    Should the bearings in the fan move?
    PM me if any of you have one.
    Thanks
    SHU
  2. VENOMOUS1 RACING
    12,753
    May 15, 2009
    Wacko Waco,TX
    Yessir, bearing in fan will move around. Usually at bottom when engine off. Nicks in blade aren't a concern but any cracks, missing pieces, or loose mounting will cause vibration.
  3. trussman
    trussman Active Member
    4,043
    6
    Aug 14, 2007
    Jacksonville, NC
  4. yellowfever#154
    yellowfever#154 Full Access Member
    3,258
    2
    Dec 14, 2007
    Lacombe, Alberta
  5. trussman
    4,043
    6
    Aug 14, 2007
    Jacksonville, NC
  6. yellowfever#154
    3,258
    2
    Dec 14, 2007
    Lacombe, Alberta
    I have a stock assembly, but it would cost too much to ship it to you.
  7. yellowfever#154
    3,258
    2
    Dec 14, 2007
    Lacombe, Alberta
    I did a ton of fan research years ago, and the one Justin uses is a OEM Dodge piece used on different vehicles and pulls a lot more air than the other aftermarket fans on the market (which is what Tony's uses).
  8. Trainman
    Trainman Well-Known Member Supporting Member
    2,360
    27
    Jun 23, 2006
    Bakersfield, Ca
    PM me your phone number, I'm in Bakersfield and I have one. Jerry
  9. Yellow venom
    Yellow venom Boosted Venom Supporting Member
    7,800
    Jul 28, 2007
    Edmonton,Alberta,Canada
  10. SHU-DOG
    816
    May 18, 2006
    PM sent.
    Drop me a note or call or email.
    Thanks
    SHU
