BAILEY1575
- Joined
- May 1, 2012
- Messages
- 7
- Reaction score
- 0
So heres the issue we have an 05 srt 10 in our shop with cold air intake and headers other than that rest appears stock they dealer traded truck when it got here it would barely run found that left 02 was bad and cat was restricted we replaced those and truck would finally run but poorly performed compression test and found left bank all under compression removed motor and found all cylinders on left bank had been fuel washed. sent motor out to local performance shop and had rebuilt and injectors flow tested ect. installed motor and replaced cam sensor due to (the fact it was installed incorrectly the first time and was broken also had ecm replaced as were not sure if had
aftermarket programing in it. HERES the issue truck runs great now but under heavy accel or pulling hill it has extream spark nock almost like its way to lean
does anyone out there have any ideas thanks kinda stuck?????? we have been running premium and engine now has 500 miles on it total vehicle milage
is 6500 miles :dontknow:
