Wouldn't be THAT bad lol....
Sound German retro harness - up to about $1100 or $1200 (from $1k) now.
An 8HP90 would be ideal (especially if modified) since the V10 JUST exceeds (by like 10 lb-ft) the 8HP70's torque input rating. 90's are harder to find but 70's are easier to find, already handle most of that power and can be built up pretty easily. It is common however for 70's to survive up to about 800 lb-ft so long as it is tuned correctly. Torque management is especially important in these units, even with the stock ones. Figure at least $2-3k if you can actually find a good used 90 (north of $6k if you need a serious one, like good for 1000 tq), even less (average $750-1500) for a good used 70, same price as a 90 to have it built to the same spec. If you're willing to pony up and can find one, the trans in the Scat Pack 1320 (70) and the Demon & Demon 170 (90) have OEM built-in transbrakes....
Electronic shifter I've seen anywhere from $50-200
Adapter plate $1500
Custom driveshaft; probably at least $1200; has to be a slip shaft because the ZF doesn't have provision for a slip yoke. This is what they use in stock 2wd trucks. Cars have independent rears so any kind of slip isn't needed since everything is on fixed points.
Trans mount is easily modified to adapt the newer trans, just maintain the proper driveline angle.
The shittiest part of this is deciding how you're going to hack up your interior to mount the e-shifter. The 2006 has the advantage here since they came with an actual console that could be fairly easily modified. The 04-05....well I have hacked up one of those dashes for a console with shifter and it was an experience I'd rather not repeat lol.
The wiring is straightforward, all you need is 12v constant, 12v switched, ground, brake switch input, tps, rpm, and reverse light output. If this gets farmed out then that adds to the cost.
The fun part is discovering that with 4.10 or 4.56 gears that 1st gear (4.71:1) is useless. I have 3.92 gears in my 2016 and 1st gear is over quickly; pretty sure it's only real use would be to get moving at max load, like pulling ocean liners or some shit lol. Towing capacity for it is somewhere north of 10k lbs.
3.54 is a much better ratio and is available for the Dana 60, though I never did figure out if it was available for this version of the D60.
Best case scenario doing your own work and not changing gear ratio: ~ $6k
Goes up sharply from there if you need a built trans and/or you need to pay for install labor.
