yellowfever#154 said:
Hey before you send it out today maybe I should have you add some of your Jeep stuff to my package, or maybe that doesnt make a difference on how it is shipped?
Send me a PM on pricing for all your Jeep items in the Red Rock Color, or something close to it.
Ill send you a PM, Thanks
bigike said:
Who got my blue caliper ide'er?
Looks awesome.
California truck that is currently in Florida for some mods, Ill let him post up if he wants too. This color is darker than what is on your truck (chrome smoke base vs. argent silver base).
HaroldD said:
Looking good Justin!!! I had a few questions for you:
1. What parts of the assembly get powdercoated?
2. Does it have a tie-in to the A/C compressor to force the fan on when the A/C is on?
3. Where does it "tap in" to sense coolant temp? With it's own probe or does it use the factory coolant temp sensor?
4. Is it on-off or a modulated fan?
Thanks - I see one in my future.
--Harold
1. The shroud setup is all coated, the fan is black plastic/metal (you can see where the fan assembly bolts to the shroud with the 5 stainless fasteners). We've done custom lettering as well on another forum members truck, it says "Twin Turbo" in SRT style lettering, very tasteful. Also HV SRT just purchased one in the cendy red, was very sweet looking. It replaces the entire stock fan assembly and shroud, so the top plate that is plastic from the factory is now all aluminum. You bolt this directly to the radiator.
2. The sensor uses a ground to override the thermostat, so I have not checked, but I would guess the factory sensor does the same for the ac compressor. You most likely could tie right in to the ac compressor trigger wire. I have not verified this though. Also there are no CEL's from disconnecting the stock fan assembly.
3. It uses a new thermostat sensor that is 3/8 npt, and comes with a nickle plated tee. You will need to remove the stock sensor on tp of the front cover and then install the tee, new switch, and stock sensor. The stock sensor needs to remain for the guage.
4. On/Off, it is factory designed as a high/low so it could be used that way if you wanted, but you would have to add your own wiring and low/high thermostat.
As with anything else I sell, if you dont want the harness or whatever, I can come up with a package to suit your needs.
Thanks
Justin
