Luck!
Copterman101
Member
Madera California
I was really lucky to find my SRT10 with only 3700 miles on it since new. Standard cab,6 speed and red. The prior owner's family was selling due to his death. I love this truck. The only thing that it needed was brake and clutch fluid change and tires. (21 year old tires were still soft but way past expiration date. LOL) Not a speck of rust or dirt on the undercarriage. Just a little dust. Now all it needs is a good detail and some paint correction and it could go back on the showroom floor, except for the two weatherstrip seals next to the windshield moulding that have been cut by the door opening and closing. Anyone have any idea where or if replacements are available?
Beautiful!!! What a find! That could be the twin to mine hahahaha!
I wonder if it belonged to a member on the forum here? Good luck with the weatherstrip it was a common issue. She's a beauty for sure !
You could search the VIN here in the registry and see if she's been registered
Weather stripping if available, its the revised version to fix the door cutting
TSB 23-049-05
1 **55277188AB** Secondary Door Seal - Standard Cab -Right
1 **55277189AB** Secondary Door Seal - Standard Cab - Left
1 **55277190AB** Secondary Door Seal - Quad Cab - Right
1 **55277191AB** Secondary Door Seal - Quad Cab - Left
Thank you for the information. None of the part numbers you listed are available anywhere with the exception of 55277191AB that is still available from Chrysler for the time being. I have a standard cab so I ordered the 191AB and cut the length to match as it is exactly the same profile as required for the standard cab with the exception of the length, but I still need a right side.
Try Andy Savakinas at Usedpartsonlinenetwork.com out of PA, even if its not on his website he might have some left
FYI,
For those out there that have the issue with the torn weather strip, here are pix of the "improved" A pillar weatherstrip moldings. These would likely have been replaced under the TB years ago.
FYI,
Had to buy my own as the dealer said it wasn't covered under federal replacement requirements like airbags are
