Power Calculations from Flow Bench Testing of Intake Air Flow
The horsepower potential of an engine can be calculated by the airflow capability of the cylinder head and intake manifold.
Airflow testing of cylinder heads and intake manifolds can be conducted on a flow bench machine and horsepower calculations can be estimated from the flow bench test data.
The standard measure for flow testing is 28" of test pressure on a Superflow 600 flow bench.
The simple mathematical formula for calculating potential power for a V8 engine is to multiply the flow bench cfm rating at 28 inches of test pressure by 2 to get the estimated power capability. This means that every (1) cfm of airflow can produce (2) horsepower in a V8 engine.
For example, a cylinder head that flows 250 cfm at 28 inches of test pressure has the potential to produce 500 hp. Although the intake airflow capacity provides the potential for two horsepower per cfm, the engine must have the best compression ratio, the proper camshaft profile and a properly tuned high flow exhaust system. Restrictions in the air intake system must also be minimized as air flow through the entire air intake system is what determines total power output.
Engine Air Flow Requirement Calculations
The airflow requirement of an engine is primarily determined by the cubic inch displacement and the rpm operating range of the engine.
This formula is best suited for engines that are near 100% volumetric efficiency (100% cylinder filling). Technologically advanced engines that breathe better than 100% volumetric efficiency may require additional airflow.
Horsepower to Weight Formulas
The horsepower to weight ratio is the basic mathematical formula for estimating vehicle performance capabilities.
The fundamental understanding from this formula is that both engine power and vehicle weight will affect vehicle performance.
Ned Erkman
Author of The Read for Speed
Ned Erkman
