camslambam
- Joined
- May 23, 2012
- Messages
- 29
- Reaction score
- 0
Hey guys.
Wondering if anyone could help me out.
Car has been misfiring for quite some time now. We went ahead changed the oil and spark plugs and seemed to fix it just fine. Then 2-3 days later started up again. This time the car would shut off when I would put it under low rpm load (reverse to 1k rpm) it would drop dramatically and shut off.
Changed the battery out and it was fine! Seemed to be perfect. Idle at 800, thing ran great. Next day (yesterday) misfire returned in the afternoon! Took it in to make sure battery and alternator were fine (battery voltage moves with rpm). At idle it sits right around 500, a little above, and moves like from 550-500. Like mentioned before battery voltage also jumps around. Temps are fine. Oil pressure fine. Everything is fine. The AC then stops being cold at idle. But when I begin to drive the car works perfect. RPM goes back to 800. Only when I stop for more than 2-3 minutes does it begin to misfire again! :dontknow:
Things got me going crazy trying to figure it out! Seems like after some driving car acts fine but if I stop it for any period of time it goes back to being moody and misfiring....
Where should I start? Injectors? Fuel filter? Maybe bad fuel?:dontknow::dontknow:
