New Dyno Numbers..please review..
jrgnd
First run was done with temp at 200 F.
Second: 180 F.
Third 170 F.
I took the Kickdown wire off and it was in tow haul mode. Started the dyno from 2000-2300 rpm.
Thanks AWDisuzu.
I already went to the track with my current setup...71 F 31% Humidity, 80 Feet Altitude, 5700 lbs racing weight
12.978 at 107.55.
Can anyone tell me why my torque curve comes down and than start's to climb up and back down...?:dontknow:
Looks like an anomaly on that dyno. I would bet that you arent making 526 ft lbs at 2400 rpms. Peak torque is more likely around 4000 rpms and you are looking at 500 ft lbs.....
Dyno numbers below 3000 RPM can be a bit squirrelly. Some shops don't even print out those numbers.
I agree that your peak torque should be around 4300-4500 RPM.
Good numbers however.
your peak trq should be around 4,200 and peak hp around 5,500. The trq number seems pretty high for the mods you have, especially at 2,000 rpm. I would go back and see if he would let you do another 3 pulls, just to be sure.
Thats right biotches it's because it's a QC.... nice dyno numbers and times mang!!! :rock:
Nice #`s.:) I want to get a baseline before the Roe project. I did 448 and 505 with just a Magnaflow and Gibsons cats and all.
