Srt10650
- Joined
- Sep 30, 2016
- Messages
- 360
- Reaction score
- 306
Not a bad quarantine day when you have 2 SRT10 trucks at home. My buddy drop off his 04 SRT10 RC for some maintenance and mods. He just got it so he wanted me to go through it, it’s an 04 RC with 83k miles. The thing I don’t like is he mentioned it has had 10 previous owners. He had the t56 rebuilt already and the front end suspension(lower ball joints, upper control arm/ball joints, endlinks, and sway bar bushings from what I seen. Replaced valve cover gaskets(washed/cleaned foam and inside of the valve covers), replaced throttle body gasket(cleaned tb), replaced the Ngk spark plugs with good ole Champions , replaced hood lifts supports(stocks were done, had to used vise grips to hold the hood up) wires were good for now(previous owners had Taylor wires with zip ties), removed center seat stock subwoofer amp(he has an aftermarket system and doesn’t use the amp) for more storage space, added a Taylor throttle body spacer, and a Grant products steering wheel. Below are some pictures.
