P1494-LEAK DETECTION PUMP SWITCH OR MECHANICAL FAULT
Discussion in 'General Discussion' started by Silver8732, May 16, 2017.
Car Parts
  1. Silver8732
    Silver8732 Full Access Member
    26
    Oct 17, 2015
    Have anyone gotten this code P1494? If so what did you do to fix the problem??
  2. earl lee
    earl lee Full Access Member
    613
    Jul 12, 2006
    Stone Mtn, GA
    I never got that particular code but I did get one related to leak detection pump, mine was for a kink or blocked line. It took me a year to figure it out, I changed the gas cap, charcoal canister, tried to tune the evap out (cant do by the way) and finally changed out the actually leak detection pump with a used one from ebay and it fixed it.
    Basically what im saying is it can be anything related to evap system on these trucks. I'd replace the leak detection pump first. You can buy a used one off ebay, they arent viper v10 specific just search for your model year truck. Best of luck, evap problems suck.
  3. VENOMOUS1 RACING
    12,753
    2
    May 15, 2009
    Wacko Waco,TX
    Gas cap or leak in lines. Vacuum hose loose?
  4. DublinOH
    DublinOH Full Access Member
    75
    8
    May 28, 2007
    I've had the same issue for years. P1494. When the weather is cooler I can use my scan tool to remove the code and it will stay off the entire Spring or Fall. As soon as the temps warm up and Summer rolls around, the code comes back. I figure it can't be that important if it only trips the CEL in the Summer. ??????
  5. kyle's srt10
    kyle's srt10 Active Member Supporting Member
    5,155
    7
    Feb 2, 2007
    Arkansas
    I have this same code in my QC. Just in the last week it started not taking fuel at the pump. It takes 5 minutes to put 5 gallons in it.:dontknow:
  6. VENOMOUS1 RACING
    12,753
    2
    May 15, 2009
    Wacko Waco,TX
    Your check valve is stuck bud. Remove and blow through full and vent lines
  7. DublinOH
    75
    8
    May 28, 2007
    Replaced the leak detection pump (took 10 minutes) and no more check engine light. Should have done that years ago.
  8. Devil's Savior
    Devil's Savior Full Access Member
    118
    6
    Mar 9, 2013
    North Pole, AK
    Where is the pump located? I am having a hard time finding any schematics, and the ones I found on The Viper Store left me even more confused
  9. earl lee
    613
    Jul 12, 2006
    Stone Mtn, GA
    You'll find it near the evap canister which is next to the big azz gas tank. It looks like this.
    https://www.ebay.com/itm/Fuel-Vapor...tection-Pump/192504492258?hash=item2cd22970e2
    Years ago I bought a used one for like $20 bucks or something and it fixed my evap check engine light.
