| Action | Estimated Cost |
| PCM Replacement | $300 - $400 |
| Dealer Replacement | $1,176 (average) |
| Reprogramming | Varies by service |
You could try usedpartsonline but before you decide you should know some people have had issues with this company but some have had no problems. Due diligence is always wiseAnyone know the best company to repair my pcm or where I can buy a replacement? Mine has the dreaded P601 code and will crank but won’t start. If it does crank, it doesn’t run long.
carcomputerexchange.com
Yes he isI reached out to Tony at JTSVP. He said he could probably help and he’ll let me know Tuesday. He’s always great!
So with that being said wouldn’t it be possible to use any doge controller as long as the plugs are the same … just have the tuner plug in your vin and install the factory program for the 10 … ???A Tuner can reprogram the used unit to the v.i.n. (No Dealer required).
What is the reason for the vin ,,,, are tunes the same for the SRT’ 8.3
NoIs it also possible to just flash or install a tune if you have a SCT into any ecm?
