Floor
How much power does a SC (ROE, Paxton) take from the engine?
A lot less than it puts out!Floor said:How much power does a SC (ROE, Paxton) take from the engine?
With the s/c it is not the loss of hp from the pulley drive (roe is minimal maybe 5-10 at the most likely less but in most s/c it is the parasitic loss of horse power IE to much heat but with the roe setup and the bugs he worked out that is very minimal with paxton I have never had one but IMO it is more of a tubo setup except instead of exhaust they use a pulley. Plus unless your getting heating issues the minimal loss of hp from it being pulley driven you will never notice it.Floor said:How much power does a SC (ROE, Paxton) take from the engine?
pokeytemplar said:This one really depends. More Boost and CFM more HP is required to turn them. So the Paxton at 8psi moving 900CFM would use 30 HP. Increase boost to 15psi @ 1300cfm and you use 83HP.
"Boost X airflow divided by 229 gives AN ESTIMATE of the HP needed at 100% efficiency." Quoted from Supercharged! by Corky Bell.
