Power Steering Pump Question
Tincup
MA.
The PS pump on the 10 has 2 ports on the reservoir, I just assumed the large on on the bottom (Red) was the return, and the smaller one (yellow) was an overflow (in case you fill it to much). When I went to fill it today, I had fluid coming out of both, are they both returns? Any help would be appreciated.
One line is for High Pressure (1600 psi +) and the other is low pressure.
There is no overflow other than straight up to the cap (messy).
I thought the over-flow was out the power steering lines...hehehe!
Haha
Yes the dreaded nylon swivel inside the hose that gets eaten by ATF+4 fluid.
Oops Dodge, oops.
