Deadworm
Wow I found more bling!
Was hunting for a plate frame and came across this lot
Big difference between "plug-in" and "amp compatible". This is what I had but I sold mine: https://www.ebay.com/itm/147581200847There is a kit that does plug in direct, I think Access makes it. DO NOT go with the Idatalink kit as its not actualy compatable. I found out the hard way and just got discouraged and decided to keep the 6disk, just opting for the FM transmitter.
Wasted on my truck, besides....better off drinking itWith your monster tank and gas prices its time to do what good ole boys do and start brewing and add some good ole high octane moonshine to the tank lol .
Im referring to the wiring kits.Big difference between "plug-in" and "amp compatible". This is what I had but I sold mine: https://www.ebay.com/itm/147581200847
Fits in the stock hole, has nav, bluetooth, backup cam capable, etc and completely compatible with the onboard amp. It's a customizable Android radio. The only thing that won't work right off the bat are the steering wheel controls and there is a way around that.
This one matches the factory hood emblems … My choiceWow I found more bling!
Ai says this ; Making the location of your red dots optimum if having to keep all 4 originals installed !Oh next on the list is i need to put widebands in for the tune with Torrie. On my old Jap cars we simply swapped out the O2 sensors with widebands but im reading I need to keep the 4 stock ones in place and then add 2 additional holes for the widebands.
Where is best to put these in? The belangers have the coating on them so would be keen not to ruin that and go down by the cat and not on the headers. Thoughts?
Can I pretty much go on these red dots after the join and in the upper 11-2 clock region?
Any idea if these plates line up front and rear with the holes on the Ram? Im assuming they do but before its 100 bucks on these frames Ive sent the question to them.This one matches the factory hood emblems … My choice
I don’t remember but believe they just added the sensors in the existing bung but reading it triggered the dash light or code . Also talked about using extension adapters to raise the sensors upward that may Avoid getting a dash light or code .. Never read that anyone had to wire in 2 more sensors adding a wide band on threads on here ! I would message or call Torrie and verify Whats he thinks or knows .
Wideband O2 sensors should be placed before the catalytic converter in the exhaust system to ensure accurate air-fuel ratio readings. Ideally, they should be located as close to the collector as possible without impeding airflow, typically between 12 to 36 inches from the exhaust port or turbo.
Havent bought them , just liked the match of the factory hood emblems …Any idea if these plates line up front and rear with the holes on the Ram? Im assuming they do but before its 100 bucks on these frames Ive sent the question to them.
What plug wires are you using or replacing ?Strip down.
Coils, plugs, leads, headers to swap out. Had a clean under there too. Some of the valve cover bolts are somewhat loose. Will be taken them off for a powercoat anyway and have new seals to go in. Those harness clip on the plenum are a bugger to get off!
Got a 170 thermostat to go in as well.
I got the livewires from JMB to go on with the heat sleeves and separators so I can do away with the stock shields and show off the Belanger. With new Screamin Demon coils in there should do for a long time but it is an awkward location for them.What plug wires are you using or replacing ?
I would love to see someone move the damn coils and mount them elsewhere to simplify replacement of coils and wires .. It rediculous having to pull the Manifold to replace those items and would not be in a very hot area of those electrical components!
I was hoping someone would move the coils to an easy accessible location lol been trying for years ..I got the livewires from JMB to go on with the heat sleeves and separators so I can do away with the stock shields and show off the Belanger. With new Screamin Demon coils in there should do for a long time but it is an awkward location for them.
Are they studs or nuts and bolts ? My guess if studs means stripped and nuts and bolts rust corroded and I would cut the off .. studs maybe wd40 a nut breaker tool on the nut side and hope the nut itself is the stripped part and not the stud threads .. … other than that a 1/4 stick of dynamite will do the trick with minimal damage lol ..So much room with these fender liners off. My manifold to downpipes bolts are spinning which isn't helpful any easier tricks to getting these off other than my usual methods of struggle?
Exhaust rear and centre off too. The rear looks stock? But the centre has magnaflow on it with pipes welded onto it. Any ideas if this is a frankenstein creation?
Oil seepage on the transmission hose at the join so will nip that up but I think these flexible ones are the ones prone to leaking and get swapped out fir stainless whats the options?
View attachment 70383View attachment 70384
Nice ,, header , well What we can see in the pic look great ..Ended up managing to cut 3 of the downpipes nut and bolts. They had the stupid cages on the end to prevent them turning but doesn't hold them still. Old exhaust all off now and Belanger going on. Also doing the spark plugs at this time and the Screamin Demon paperwork says to gap them to 0.065" which seems big. The old ones were probably due a change and the rear one somewhat fell apart.
Rubbish dark picture but looking good and the gaskets are alot better than those multi shimmed metal ones. Dropping the centre pipes off tomorrow for wideband bungs after lining up the orientation and finding room. 11 o'clock position seems to look good on both sides.
View attachment 70385View attachment 70386
