Project Lula
Here is a pic of the plugs I had in for a good while years ago..
There worn down and the one on the right I must have hit or bummed something to install it new .. Back passenger side .. gas mileage after installing went down about 2 mpg .. no misfire I could feel no power problems … several years later I took a road trip ad then notice a very slight skip of the engine and a very slight ticking .. when I got back home I checked codes and was showing some missfire code actually 3 codes related but didn’t give me the bad location … can’t remember the codes now ! I was thinking something really bad has happened ,,, Started pulling plugs and found the bent one .. with fingers crossed replaced all the plugs and everything was fixed and mileage jumped back up , no more ticking sound ,, ran smooth and still does today ..
As you can see that plug and the soot on it was worth a negative 2 mpg lol surprising it fried at all and caused no noticeable misfire for a couple years
The recommended gap on the plugs at .65 does seem wider from my memory..
measure the gap on the old plugs ? The old plugs look decent and not very old . Close up would show a better picture of their condition .. looks like the truck had a slight oil leak at the valve covers to the plugs or just grunge build up ..
Some of the valve cover bolts were finger loose so I think there was some oil seepage. Screamin Demon state a .065" gap to be used but I've found quotes seem to go to .045" so will go with that instead. Im sure this will all make a remarkable difference.
You could always experiment with the gaps if/when you Dyno it and see if it shows any difference .. hotter colder plugs also come to mind !
Checked my plugs that were removed and gaps were .045-.055. Seem even more aggressive for the setup. Will be glad to get a baseline and a tune.
Both headers on now and plugs changed with new leads and coils.
You’re on a roll …. Great progress .. soon on the road again tearing up the pavement lol
Had to raise the bed slightly to get to the fuel tank hose to do the full stainless swap bit of a pain but another job done. Leaving it up fir now to check for leaks later on. Have an adapter in the new line for fuel pressure gauge.
Cracked the bottom coolant hose for the new one while I have loads of room and at the same time swapped out the thermostat for 170 version.
My gauge pod has arrived now to house the stock gauge plus fuel pressure and wideband. Will be the focus tomorrow to start wiring these into position.
Have crank pulling to do as well but not sure if I can get this with the radiator in.
Crank pulling ??
Nearly got it damn auto correct just the pulley and no pulling.
I was thinking spellcheck .. We can put a man on the moon yet can’t make a spellcheck work hahahaha !
Hopefully I've wired this all in right. Got the SCT fireworks cable wired in to the 2 wideband sensors and also the RGB cables for the 2 gauges to plug into laptop so quite busy behind there. Need to pull a switched pos out of the engine bay fuse box next to power them.
Waiting on valve covers coming back, plenum from the shop and exhaust wideband fabrication before I can make any more real progress. The new grille will be heading off to the sprayshop as well this week.
Caution, you should retorque the head bolts while in there. They do have a habit of coming loose at the rear. It will start a small amount of coolant loss above starter motor. I have SD coils to. I settled at 55 thou. There is a lot of different opinions about single blade TBs. The common dislike is the air that goes inat the middle hits a wall and gets deflected, causing turbulence and slows down the air going in from the sides. The twin butterfly versions send the air direct down the two sides without the disruption. I am not an expert but it makes sense to me. I have not seen any dyno tests of the comparison. Hopefully someone will jump in with more concrete detail.
Just remember the auto trans is weak and usually fries. Ronnie can tell you more about that. Best to find a good trans shop that can build you a strong one for the diesel.
@Deadworm
Where did you get the template to do this ?
You can get them at Venomous1racing. Though from seeing his profile here he may have done something wrong and got a boot idk just a guess. I found him through a Facebook group recomendation. Seems like a decent guy to me, he helped me with a PS pump and hoses when I blew mine up. He is bassed in TX. His name on FB is Scotty J. Forman. He said his website is a second though vs messaging him directly and may not have everything he offeres listed.
Cool thanks
In my searching I thought he had got booted from here too and was wary ordering from him but he has been an absolute pleasure to deal with and I will be getting more from him. A bit difficult to get information out of like tell me what parts does your lowering kit contain. Ironically I had issues with one of the bigger part sellers in the US and have a claim going through still.
