Ram turns off
Discussion in 'General Discussion' started by Ajacs, Jun 15, 2020.
Car Parts
  1. Ajacs
    Ajacs Full Access Member
    14
    Oct 7, 2016
    Hi all
    The problem is following, sometimes when I running the car suddenly turns off, it wan't start untill i wait 3-5 minutes , than it runs great, in the last time that repeats more often, any ideas how to solve it? I think it might be IAC, please help!
  2. Ajacs
    14
    Oct 7, 2016
    Or maybe its the problem with crankshaft position sensor???
  3. Teddy
    Teddy New Member
    2
    Dec 28, 2014
  4. Teddy
    Teddy New Member
    2
    Dec 28, 2014
    I had the same problem a few years ago. A few months prior I had replaced the OEM throttle body with a new BBK throttle body. The truck drove fine for a couple of months then one day it just stopped. I would wait a minute or so then it would start. It would do this on and off for months. I noticed when it stopped that the fuel gauge did not read or went to empty even if the truck was full of gas. I replaced the IAC and the crankshaft sensor but still the problem would return. The truck stopped one day so I started checking for a loose wire or bad connector. I heard a electrical spark while I was checking wires near the throttle body. Turn out to be the wires to the Throttle Position Sensor connector were loose and not fully seated. I moved the wires and noticed the fuel gauge started to read and she fired right up. I pushed the wires in until them were fully seated and the problem was solved.
  5. Ajacs
    14
    Oct 7, 2016
    well ive checked twice all of connectors under hood, it seems fine, and it repeats more often ...and I also feel problem with an idle , it rise up suddenly and fall down
  6. AMS3
    AMS3 Active Member
    298
    107
    Aug 8, 2019
    Savannah Ga
    Sounds like you need the expertise of RottenRonnie. Him and some of the others are a wealth of knowledge on these trucks.
    Kiwi SRT10 likes this.
  7. 505
    505 Full Access Member
    48
    13
    Sep 7, 2018
    Orlando
    just had this happen last friday. runs fine, sputters and dies. Did it once, then again. One thing I distinctly noticed was when it died and I tried to start it - it sounded like the injectors weren't sending fuel, or there was no spark. It sounded not right. Towed it home there was a crankshaft positioning sensor code in it. It would start and idle in the garage, but it had that code. They don't set them for no reason. So I swapped the crank sensor. all good.
    rottenronnie likes this.
  8. TrailMix
    TrailMix Full Access Member
    79
    6
    Feb 3, 2011
    Mississippi
    Just make sure it's mopar part or you'll be changing it in a week or less
