Replaced front turn signal bulb
WA 2 FST
Allen, TX
It's an extremely simple job ... EXCEPT getting to the outermost bolt to remove the headlight assembly. With our bumper covers, it is not easy, even with decent extensions. if I had an extra set of hands, it would have helped, certainly.
I made sure to cover the bumper with a microfiber towel and press down on bumper cover in order to get socket in there to access the bolt. Going back in was difficult too b/c the bolt in the socket succumbs to gravity and is thus very hard to line up (bolt hole is a good 6" behind the bumper cover).
A 5 min job took 20 mins. oh well.
What I should have done was replace the headlight bulb as well while I was in there. :p
Did you take out the plug in the wheel well liner and go through that hole? I am replacing my whole headlights with the Night Runner type headlights and will have to do this soon. I might just take off front bumper again since I have other stuff to do as well, and maybe the wheel wells too.
I found a 6" extension from my ratcheting screw driver worked really well. I did push down on the cover just to be sure, but it wasn't too bad.
I'm going to get a 10-12" extension for the next time I have to do the job. Would have made it much easier. Regardless, its a tight fit, I think (which isn't a bad thing, of course, from a fit/finish standpoint).
Chewy... I did not take out the wheel well liners... no real reason to do that, I don't believe.
That hole in the wheel well liner for headlight removal is 06 only. On the 04/05 models the three bolts are on the front of the lamp.
You got to make it happen. The truck won't fix it's self.
Told this to many a frustrated technician.
