azpyroguy
For the past few months maybe twice per day the truck while driving would act like it wants to die... the tach would go nuts, it would richen way up, and then return to normal.. all in matter of 1-2 seconds (barely enough time to see the tach bounce around...)
But it would never throw a code... so I had no idea where to look...
So, last night on the way back from dinner it did it again... but this time the CEL came on.... so I got it home, and found that it was a P1391, Intermittent Crank Position/Trigger Signal.
I unplugged the battery last night, and let it sit overnight.
This morning, I tore into the only place I could think of, and that was the location I spliced the Split Second box into harness at...
Did not find anything really interesting.. but figured that I would cut and reconnect all the wires, but this time instead of using solderless connectors, I decided to solder all of them...
So I drive it around for about 20 miles after I completed it... and seems to have taken care of the problem... it also seems to idle better now... maybe I had a loose wire or something... time will tell.
