Slave Cylinder Help
Discussion in 'General Discussion' started by Ready2Bite, Mar 24, 2019.
Car Parts
  1. Ready2Bite
    Ready2Bite Full Access Member
    51
    May 21, 2014
    Windsor, Ontario
    I think my slave cylinder for the clutch is shot. When I push the clutch pedal there is no resistance at all. How big a job is it to replace this? where can I get a new one? I can't drive the truck right now and spring is here so I have to fix it. Any advice/help?
  2. Ready2Bite
    51
    May 21, 2014
    Windsor, Ontario
    I've called the dealership and they are saying the part is discontinued - I need to find a source for this part - any help would be appreciated
  3. 96indyshaker
    96indyshaker New Member
    10
    2
    Dec 16, 2018
    Auburn,Indiana
    I'm a new guy. But I think i read somewhere about someone changing to one from a viper.
  4. Michael from the U.K.
    Michael from the U.K. Member Supporting Member
    313
    7
    May 22, 2006
    Berkshire in England
    What’s happened to the helpful advice on this forum?
    I guess you have checked the fluid,but yes the Viper master/ skave cylinders are considered an upgrade on these trucks.
    Good luck.
  5. Stu05srt
    Stu05srt New Member
    2
    Feb 4, 2019
    Hey, I just had the same problem! Order one on roeracing, its an upgrade kit i believe from viper.
    Transmission has to come off, its not really that bad of a job!
  6. Slitherbeast
    Slitherbeast Active Member Supporting Member
    2,260
    8
    Sep 10, 2007
    Alberta
    Try to bleed the cylinder while you wait for the NEW slave assembly.
  7. Ready2Bite
    51
    May 21, 2014
    Windsor, Ontario
    Hey folks - thanks for the advice. I just got back from a business trip and will be looking at the truck next week. I'm going to try bleeding it first and go from there.
    I'll post next week and let you know if bleeding it works.
  8. Tcorsrt10
    Tcorsrt10 New Member
    19
    7
    Dec 8, 2018
    Keep us updated ......
  9. Ready2Bite
    51
    May 21, 2014
    Windsor, Ontario
    Well, trying to bleed the cylinder didn't work. Fluid just pours out the bottom of the housing so the cylinder must be cracked!! Just hoping now that the clutch hasn't been contaminated with fluid! what are the chances of that happening? I couldn't get it to build up any pressure so it appears it is just draining out. I guess it's time to pull the tranny and get the parts and fix it properly so it doesn't happen again.
  10. Blackbetty
    Blackbetty Member
    38
    16
    May 12, 2016
    I'm doing the exact same thing right now too. this is my second time. I got the transmission out and back in in about 7 hours. advanced has the u joint strap kit for like 8 bucks every one else is asking at least 25 bucks. take apart in this order
    drain tranny fluid,
    drive shaft, go in side the truck remove the shift knob it screws on, then remove the cup holders 3 8mm bolts that should all slide up and over the shifter, then a dust cover with i think 8 8mm bolts, you can then see where the shifter connects to the tranny with 4 #6 allan key bolts remove those and then stuff a clean rag in the hole to keep debris out of it, wrap up that shifter end with a clean rag as well, disconnect the quick connect from the slave, un plug the 2 transmission sensors, you dont have to do this part but i did for extra room but disconnect all the o2 sensors. then remove the tranny from the mount by removing the 15mm bolts the 18 8mm on top of those are welded on so don't worry about those, then your bell housing bolts there are 10, support tranny with the tranny jack remove the tranny mount brace 18mm nut and bolt, remove tranny, then 1/2 inch bolts hold the slave in place use an open end wrench it's a weird angle to access them then put it all back together
    Michael from the U.K. likes this.
  11. Blackbetty
    Blackbetty Member
    38
    16
    May 12, 2016
    orileys had the master cyl you have to go on eBay and order a luk master stl in you want the hose and AutoZone has the slave cyl
  12. Blackbetty
    Blackbetty Member
    38
    16
    May 12, 2016
    I don't reccomend doing the full viper slave "upgrade" because the master cyl won't work for it and it's a bit different I think it compresses differently.
  13. Slitherbeast
    2,260
    8
    Sep 10, 2007
    Alberta
    I Have the Viper Upgrade from JMB. It comes with 2 shims. The slave is about a 1/4" short.... It works great with the centerforce clutch. Been in the truck 8 years but only 35,000 miles. GET THE BRASS SHIFTER BUSHING! takes all the slop out of the shifter! the plastic one will be gone......
    Psycho1122 and TXThumper like this.
  14. Ready2Bite
    51
    May 21, 2014
    Windsor, Ontario
    Slitherbeast: do you have a P/N for the brass shifter bushing? I'm thinking of the RoeRacing Upgrade kit - plan is to keep the truck for a few more years and don't want to have to do this again. where is JMB Located? I'm in Canada but can ship it to my son's place in Detroit area.
  15. Ready2Bite
    51
    May 21, 2014
    Windsor, Ontario
    Still wondering about potential clutch contamination - thoughts from anyone? I put fluid in - it just bleeds right out if I push the clutch pedal so I'm thinking that once it's expanded the fluid is draining straight down and the clutch friction plate should be fine. Probably won't really know until I take it apart no?
  16. Ready2Bite
    51
    May 21, 2014
    Windsor, Ontario
    Who/What is JMB? any links?
  17. Ready2Bite
    51
    May 21, 2014
    Windsor, Ontario
    Roe Racing has the upgrade kit for $600 US. Supposed to come with complete instructions for installation - anyone use this before? Experience? Good/bad?
  18. Snake Charmer#04
    Snake Charmer#04 New Member
    7
    4
    Jul 25, 2016
    Yeap! I just put a brass shifter bushing. In my 04 2/Doors Dodge Ram srt10 (silver).
    Slitherbeast likes this.
  19. Michael from the U.K.
    313
    7
    May 22, 2006
    You won’t go far wrong with Roe
  20. Slitherbeast
    2,260
    8
    Sep 10, 2007
    Alberta
    Sorry! It was "the Gear box" The parts are listed on their website. http://www.thegearbox.org/T56.html
