SNOW METH KITS 20010 BOOSTED APPLICATIONS 3 DAY SALE $390 SHIPPED
(TO LOWER 48 STATES ONLY, OUT OF US SHIPPING APPLYS)
I also have 4 gallons of the Snow boost juice comming if more is needed let me know
$10 a gallon, but shipping will apply
any other kits needed let me know and will do what I can also on those
********SALE ENDS SUNDAY NIGHT************
Stage 2 Boost Coolerâ„¢
This kit uses manifold boost pressure to determine when and how much fluid to inject. Proportionally injecting according to boost pressure gives the most accurate delivery of water-methanol and allows the most cooling and performance improvement over the widest range. More power and driveability is the result. It can be used on any forced induction engine: carbureted, fuel injected, turbocharged, positive displacement or centrifugal blowers. The most suitable are the centrifugal supercharged and turbocharged engines, as they build boost is a more progressive manner concerning water-methanol injection. The positive displacement blower engines will work, but it might take more work to dial in the delivery. For higher boost applications (over 25psi), the controller can be upgraded to our VC100 unit. Now with Lifetime Warranty - please see details.
Kit includes:
• UHO (Ultra High Output) Pump
• 3 Quart Reservoir
• Digital Variable Controller
• 2 Nozzles To Cover a Wide Range of Horsepower
• All Required Hardware Needed For Installation
• Comprehensive Instructions
Boost Juice™ is Snow Performance’s proprietary mix of 49% methanol and 51% water. It is made in a controlled environment with special care to make sure the ratios are accurate to result in a high performance water-methanol fluid formulated for use in the Boost Cooler™ injection system. Boost Juice is required as the exclusive fluid for lifetime warranty.
20010
Kit includes:
• 3 Quart Reservoir
