master_328
- Joined
- Sep 1, 2012
- Messages
- 12
- Reaction score
- 0
Hi folks, I bought a SRT-10 with a taped CEL. The reason for the preowner to tape the check engine light is fault P1494.
I always get this fault stored after a cold start. I followed the procedure to solve the fault, but I didn`t suceed yet.
Gas cap seems to be ok, I can`t smell fuel or anything else
Hoses seem to be ok
Vacuum supply is ok (about 15 mmHg)
1. using the search, I read about a software update of the ECU. My truck is a yellow fever, so it should be from 2005. Is there any update available?
2. Point 5. in procedure says "ldp switch sence circuit short to ground"
resitance should not be more than 100 ohms. I measured 400 ohms
3. is there any possibility to solve this terrible prblem without removing the system. Can I maybe block a hose, so that the system always gets its vacuum?
Thanks for your help
Hoses seem to be ok
