Start Button Issues ?
Discussion in 'General Discussion' started by SRT10FOUR, Sep 24, 2021.
Car Parts
  1. SRT10FOUR
    SRT10FOUR Member
    66
    35
    Apr 6, 2020
    Anyone ever have any intermittent issues where the start button needs to be held down rather than the usual momentary push to start?
    I have a brand new battery that I had checked out by the shop and they said everything is perfect with the alternator charging, the battery, the cables, voltage, etc. but I couldn’t leave it with them to inspect further.
    But about once every 50 starts, it requires me to either hold down the start button or mash it like a Nintendo controller for the truck to start. And everything ends up being just fine. Next 49 starts are perfect lol ?
  2. Viper Truck Registry
    Viper Truck Registry Well-Known Member Staff Member Administrator Supporting Member
    36,753
    347
    Idaho
    Time to buy or starting looking for a {fun} button before it goes completely bad and they are no more, if not already
  3. shirleyjp86
    shirleyjp86 Active Member
    70
    108
    Jun 11, 2021
    Lavonia GA
    Could be the PCM and the way it's interpreting the signal, if it's doing it every 50th start, or mimicing some other increment or pattern. If it's just sort of random, I'd bet the copper contacts inside the swich are worn down. You may be able to take the switch apart and clean the contacts with alcohol and possilby use tweezers to gently bend them outward just a tad.
    Kiwi SRT10 and AMS3 like this.
  4. shirleyjp86
    70
    108
    Jun 11, 2021
    Lavonia GA
    Starter Push Button Ignition Switch RAM SRT10 Viper OEM – Viper Parts Depot
    Here ya go, brotato chip.
    Kiwi SRT10 likes this.
  5. VIPR PWR
    VIPR PWR Full Access Member
    4,993
    272
    Jun 12, 2007
    FL
  6. shirleyjp86
    70
    108
    Jun 11, 2021
    Lavonia GA
    It's not exact, but it should work.
    Wifey likes this.
  7. Kiwi SRT10
    Kiwi SRT10 Well-Known Member Supporting Member
    967
    1,000
    Dec 16, 2019
    New Zealand
    If it's a manual it can also be the clutch pedal switch. I am going to remove the one on my truck as it is a serious pain in the rear
    Wifey likes this.
  8. Wifey
    Wifey Well-Known Member
    23,065
    337
    May 18, 2006
    Taxifornia
    I can't believe you really count!!! LOL LOL
  9. Wifey
    23,065
    337
    May 18, 2006
    Taxifornia
    close enough for government work hahaha
    shirleyjp86 and Kiwi SRT10 like this.
