Think this will help us?
Interesting. Is the 8.0 liter a Gen 2 engine? Or the Iron head I'll have to look it up
8.0L Viper V10 (Generations I & II, 1992–2002)​
The original 8.0-liter Viper V10 debuted in 1992, producing 400 hp in early Gen I models and featuring an aluminum block derived from a truck-based design refined for high performance. In Generation II, output increased to 415 hp in the RT/10 and 450 hp in the GTS coupe, with later ACR variants reaching 460 hp. This engine established the Viper’s reputation for massive torque, minimal electronic aids, and raw driving engagement.
How did they (Bristol) get this kind of HP from the 8.0?? Article says 525 and later 600
Maybe the columnist made it up !!???!!! Seems they should be more specific
I researched and the only possibility is the 8.4L GEN 5 version which does put out that HP. Bad journaliism lol
Could be bad journalism, but if you look at all the photos and pictures that you can find online, definitely not the same intake. It’s an 8.0 intake.
Well then maybe it's bad research!! Hahaha
Not sure but maybe someone will pipe in
Wikipedia info
Says a modified version so that must be the deal......
British luxury car manufacturer Bristol Cars: the Bristol Fighterwas powered by a modified version of the engine which produced 525 bhp (532 PS; 391 kW), increasing to 550 bhp (558 PS; 410 kW) at high speed due to the ram aireffect.[9] Bristol Cars further produced a Fighter S, in which the engine was tuned to give 628 bhp (637 PS; 468 kW)(660 bhp (669 PS; 492 kW) at high speed). Bristol had also planned to produce a Fighter T, further modifying the engine with a turbocharger to produce 1,012 bhp (1,026 PS; 755 kW)at 5600 rpm.[10] However, Bristol have since stated that no Fighter T models were produced[citation needed].
Ask grok he knows everything (;
Wikipedia info
With a,tune and ram air effect ??!!??
I don’t have rock anymore. I just use it on whatever AI is on the browser if I use it like DuckDuckGo has AI on their browser.
Looks like it is NOS Bristol had already acquired b4 shutting down so many years ago. So it won't help us with availability of engines or parts. With production low enough to not wakeup the aftermarket and probably not really fight us for what is available.
Still pretty cool to see new cars with a Viper engine though.
It isn't particularly difficult to produce 600 flywheel from a Gen II. (It may even be a Gen III with the Gen II Intake in the picture).
An article I posted on the Internet years ago when I was a Distributor for JM Cylinder heads (Striker), is now on the Southeast Performance site (Kiwi SRT 10's build), in its entirety, if you want to spend some time reading through that info...Put on the coffee.
You will see that (properly) ported o.e.m. heads provide a nice power boost, albeit not the same as the Strikers did.
Jeff hit a power wall modifying/porting the o.e.m. castings and Strikers were the cure.
Keep in mind out of the box Strikers can also be (properly) ported for even more power.
