I never knew what to pick if a performance shop didn't tell me. Strokers based on modern tight clearance engines (especially with stock oil pumps) get the crank clearanced for what the builder chooses. But then rest of the clearances (lifters, cam bearings, etc.) may or may not complain. Plus supercharging can put a tremendous amount of stress on the rod bearings.
Had two cars I tried putting thicker oil in to quiet some piston slap when cold. On one, the slap got quieter, but then the hydraulic lifters and/or rocker arms got clicky. Changed oil back after a hundred miles and it went back to the way it was.
The other one? Negligible differences. Thicker oil quieted the slap, had a couple more PSI of oil pressure at idle, and lifters were silent before and after the change.
Beats me. Guess I would have to go wild with bore gauges and micrometers to find out.
