Voltage issue
Discussion in 'General Discussion' started by ViperPete, Jan 15, 2018.
Car Parts
  1. ViperPete
    ViperPete Full Access Member
    2,649
    5
    Aug 4, 2010
    Ocala, FL
    OK so here's whats happening.
    If I drive the truck and don't run the heater/headlights/ stereo the voltage stays at 14v with the truck at idle. If I run the heater/stereo/headlights or any combination of the 2 at idle the volts drop to around 12v. Once i start moving the volts rise to 14v.
    The battery also does't fling the motor over like it used to. I think my alternator must be going bad and that's killing the battery.
    Maybe it's time to replace the alternator but I don't want to replace it with another stock unit. Does anyone know of a higher-output alternator that will fit our truck?
  2. IronAffliction
    IronAffliction Full Access Member
    563
    Apr 27, 2015
    yelm WA
    Sounds like the alternator. Do you have a big stereo system or something pulling lots of amps? Of not I would just go with a normal alternator but thats just me
  3. ViperPete
    2,649
    5
    Aug 4, 2010
    Ocala, FL
    I have 2 amps. 3 sets of Infinity Kappa Perfect Components and 2 10" subs. I also have HID headlights.
    Def want more output if I can get it.
  4. sublimeswinger
    sublimeswinger Full Access Member
    178
    Apr 9, 2015
    Santa Clara, CA
    That is plenty for a stock alternator. your voltage sounds right , even with everything running
  5. ViperPete
    2,649
    5
    Aug 4, 2010
    Ocala, FL
    The gauges and headlights dim at a stop light. That is not normal. It is not normal for the voltage to drop 2 volts with the truck at idle and to go to 14v at 1000 rpm or higher.
  6. blazinsrt
    blazinsrt Full Access Member
    277
    2
    Jun 12, 2016
    Philly, PA
    I would look for a rebuild kit if they are available. Prob a lot cheaper and its not hard to do.
  7. Slitherbeast
    Slitherbeast Active Member Supporting Member
    2,270
    15
    Sep 10, 2007
    Alberta
    Could be a loose belt. Confirm your tensioner is still strong and not seized. try a new belt then see what the voltage does..
  8. earl lee
    earl lee Full Access Member
    613
    Jul 12, 2006
    Stone Mtn, GA
    What brand of battery you using and how old is it?
  9. ViperPete
    2,649
    5
    Aug 4, 2010
    Ocala, FL
    The belt is pretty new. I doubt its the belt as the alternator performs perfect above 1k RPM
    Not sure of the brand i think its Autozone brand. But it is at least 5 years old.
    I'm gonna throw a new battery in it and see what happens before I look into an alternator.
  10. JTS VENOM PERFORMANCE
    JTS VENOM PERFORMANCE New Member Preferred Vendor
    33,544
    SRT10 heaven
    you should do a draw test, and an alternator load test to be sure, just guesing is just that a guessing game,
    but if you are running a couple amps, its more than likely having a hard time keeping up
    get ahold of js alternators in sc, he has an upgraded unit that will work perfect for your set up.
  11. earl lee
    613
    Jul 12, 2006
    Stone Mtn, GA
    A new battery is cheaper than a alternator plus given the age of your battery its likely time to replace it anyway. Battery might not be able to hold a charge as well, putting a strain on the alternator.
  12. ckjarr
    ckjarr Full Access Member
    47
    8
    Nov 15, 2012
    I don’t post very often but thought I would chime in here as I’m experiencing similar symptoms. I installed an Optima Red Top battery a couple years ago and started experiencing very “sluggish†startups this past summer so I took it back to Auto Zone to get the battery tested and it checked ok. After discussing some of the same symptoms you mentioned, he did the load test Tony suggested and said the alternator was doing it’s job as well but said the truck was not producing the voltage it was supposed to be producing. After some digging it didn’t take long to learn, as I’m sure most already know, the voltage regulation is controlled by the computer. Hopefully yours is simply the alternator as there’s not many options out there for us. I’ve been researching a little and when mine completely lays down I may try to splice in an old school external voltage regulator instead of replacing the ECU. Anyways, good luck with finding your solution!
  13. ViperPete
    2,649
    5
    Aug 4, 2010
    Ocala, FL
    Got a new battery. The engine starts instantly now, but there is no difference when sitting at a stop light with the headlights and heat/stereo on. Voltage still drops to 12 and then rises to 14v when I raise the RPM.
    Guess I need a new alternator that has more voltage at idle.
  14. sleepersrt10
    sleepersrt10 Member Supporting Member
    87
    Nov 24, 2006
    Middleburg, FL
    Are you running underdrive pulleys by any chance? If so, is the alternator just not turning fast enough at idle? Just a thought...
  15. ViperPete
    2,649
    5
    Aug 4, 2010
    Ocala, FL
    Yes i have an under drive pulley. I priced out a new stock pulley/tensioner/belt and its only a little more and i can get a 210 amp alternator. Might just go that route. My alt is 13 years old.
  16. earl lee
    613
    Jul 12, 2006
    Stone Mtn, GA
    Didn't know you had a under drive pulley, that with what is likely an original alternator is likely your problem
    I was going to ask about the last time you changed your serpentine belt. I just changed mine with a new one, and noticed the old one had looked like it stretched itself an extra inch.
    Putting belts on these trucks are PITA as well.
  17. aldrinledwidge
    aldrinledwidge Full Access Member
    10
    Feb 25, 2016
    Oak Harbor, WA
    Please, someone, explain to me "underdrive pully".
    Al
  18. VENOMOUS1 RACING
    12,753
    May 15, 2009
    Wacko Waco,TX
    It will charge slightly less sitting still at idle, but in the years I had it on my truck and over a 150k miles, never caused an issue one. 12.5 at idle is perfectly fine. Will not cause slow starting! That's the battery. Many don't give it sufficient cranking Amps when buying new. 850-1000 I like to see.
  19. IronAffliction
    563
    Apr 27, 2015
    yelm WA
    Its a crankshaft pulley that is smaller than stock and adds a few ponies buy freeing up some of the loss caused by the accessories
