Weight Reduction- weights of parts- ACCURATE!
Discussion in 'Performance Mods' started by VENOMOUS1 RACING, May 4, 2011.
  1. VPRPWRD
    10,835
    Mar 28, 2012
    PA
    I got rid of my spare. Honestly the best weight reduction / traction mod I made was removing the front sway bar. Special thanks to Arrestmered04 for that one :D
  2. caveman
    caveman Well-Known Member Supporting Member
    7,500
    25
    Jul 20, 2011
    Western Colorado
    With the sway bars? Do you have a single list of everything you have done?
  3. stealth78
    stealth78 Full Access Member
    2,606
    7
    Feb 15, 2012
    MA
    Do u put it back in for everyday driving? Does it affects ur handling?
  4. VPRPWRD
    10,835
    Mar 28, 2012
    PA
    I have yet to put it back on and to me it drives no different.
  5. SergioL.
    SergioL. Full Access Member
    398
    May 19, 2012
    Pasadena, Tx
    Would removing the rear sway bar hurt?
  6. VENOMOUS1 RACING
    12,753
    May 15, 2009
    Wacko Waco,TX
    Sway bars DO help with sway or the feeling of the body rolling or leaning around corners. Won't affect most normal daily driving. Hard cornering will be very noticeable minus sways.
  7. VENOMOUS1 RACING
    12,753
    May 15, 2009
    Wacko Waco,TX
    My bad..RC I'd say 5350:D
  8. SergioL.
    398
    May 19, 2012
    Pasadena, Tx
  9. VENOMOUS1 RACING
    12,753
    May 15, 2009
    Wacko Waco,TX
    It protects our plastic fuel tanks from damage. Driveshaft especially! My shaft beat the shiat outta that piece when my shaft let loose!!
    In other words mine's staying, lol
  10. SergioL.
    398
    May 19, 2012
    Pasadena, Tx
    :eek: 10-4
  11. VENOMOUS1 RACING
    12,753
    May 15, 2009
    Wacko Waco,TX
    R happened in H Town at Hennessey's track! Cheap u joint strap kit from Vatozone ripped:vollkommenauf:
  12. Trainman
    Trainman Well-Known Member Supporting Member
    2,376
    49
    Jun 23, 2006
    Bakersfield, Ca
    Take it from one of the quickest NA trucks on this site....loose all of the weight you can! In my opinion extra weight NEVER helps.....unless you're trying to go slower.....but then again.....what do I know:D You can listen to the guys who run 13's or the guy who runs 11's, your choice!
  13. Trainman
    2,376
    49
    Jun 23, 2006
    Bakersfield, Ca
    I removed mine several years ago, per ArrestMeReds advice, and I never put in back on. I have over 64,000 miles of driving and I can't tell any difference, and although I don't road race , I do drive 75-80 on the freeway and have no touble with the fast turns on the highway, I even drive home from the strip with 16lbs of air in the slicks and 50lbs in the front tires , and the truck handles just fine at freeway speeds. The sway bar is 26.5 lbs.
  14. rare03srt10
    rare03srt10 Full Access Member
    2,941
    Feb 3, 2011
    Fountain Valley, CA
    When i broke my driveshaft a few months back it hit that metal sheild hard to and scratched it up good, but my tank was not hurt one bit. MINE STAYS FOR GOOD NOW ALSO lol
  15. ARRESTmeRed04
    ARRESTmeRed04 Active Member Supporting Member
    5,882
    2
    Nov 5, 2007
    central texas
    Leave the rear bar on, it keeps the axle from trying to twist and lifting the right tire up loosing traction
  16. stealth78
    2,606
    7
    Feb 15, 2012
    MA
    Damn! 26.5lbs!! I did hear at one point the sway bars were beefed up on the 06's so mine might be another couple pounds.
  17. viperhauler
    viperhauler Active Member Supporting Member
    18,943
    22
    Jul 27, 2008
    i know for a fact that the guy who has no experience, and no other "lightening" mods who removes 100 lbs. from behind his axle will lose time... guaranteed...
  18. SrtBrad
    SrtBrad Michel Productions
    12,870
    7
    Feb 10, 2007
    Weight is weight
  19. caveman
    7,500
    25
    Jul 20, 2011
    Western Colorado
    No way, Dude. 100 pounds makes a bigger difference on the big end than the slight difference on the launch. Maybe we need to do some testing?
    Good advice! Thanks.
  20. stealth78
    2,606
    7
    Feb 15, 2012
    MA
    One thing that drives me nuts about the weight distribution on these truck... we sit obviously on the drivers side, extra weight on that side from all the steering components... Dont you think that Dodge would have tried to offset some weight with the battery and fuel tank??? Nope, stuff all that on the drivers side too. I've really been wanting to do the battery relocation to the bed, but I've read that some people have had starting issues with all that extra cable. Any info from guys who have done it?
