moparracing
from my recent pir drag racing experience, it's readily apparent that i need drag radials....... rottenronnie went with the American Eagle Alloy 058 series 17" (0589-8057 17x10 Polished 5 on 5.5 - Acorn, -24mm offset, 4.5 backspacing, N/I, 2100 lbs., 26 lbs) and the 390-40R-17 M&H Racemaster drag radials.......
rims from TMC & tires from M&H.....?
run about 22psi @ the track ?
can i use the stock lug nuts ?
should i use the 325/45/17's or 390/40/17's (taller/wider) ?
rim cost between $85.00 to $120.00 ?
what are others using & their costs ?
thanks for your input.
http://www.aewheel.com/wheels_detail_specs.cfm?id=23
http://www.mandhtires.com/store.php?crn=70&rn=295&action=show_detail
http://www.mandhtires.com/store.php?crn=70&rn=305&action=show_detail
