Ronnie's NA Build
Use the white truck to tow the black truck to the track and go and have some fun.
Bolt on your Drag Radials, drop the pressure to 7 psi.
Hold the revs right at 6000, dump the clutch and hang on.
It will be fine....:p
Sounds like good advice!:D:D
Hey- Did you get your Monster Catch-Can dialed in yet?
That "stuff" they collect is foul.
I'm not sure how I'm going to keep the shaft of my Throttle-Body lubricated now that it isn't soaked with oil anymore.:p
$71.50 for one person and truck to catch the ferry over to Vancouver Island. ($143 total with my son and his SUV two spots back in line). I remember when my dad would bitch when I was a kid about is costing $20 for a vehicle and a family of four!
I remember 2 bucks per vehicle and 50 cents per person; but I'm a fossil.
5500ft difference in DA.....would have been fun....
Count on losing 3.5% for every 1000 foot increase in altitude.
3.5% x 5500 feet = a 19.25 % loss
So with your SRT-10 you are down nearly 130 flywheel horsepower with a 5500 foot D.A. in Calgary:banghead:
OR
Drive to sea-level like you did and GAIN 130 horsepower! :burnout:
:rock::rock::rock:
Ronnie, For your engine build, Did you do any oiling mods to the rotating assembly?
Just the little bath-tubs in the upper (block) main saddles, coated the Gen IV bearings, rounded off some oil passages and went to a (1) piece shuttle for the relief.
Oh, and 0-30 to reduce oil pressure a bit.
Crank was hardened & polished and with the new main caps, trued (align-bored) on all axis.
NO pressure wavering using a LARGE mechanical oil pressure dial-gauge during 6500+ runs.
So...No, there was no side rod clearance increase/decrease nor oil-hole mods to the crank.
I left the OEM crank-scraper in place.
Thousands of miles and still going strong...
2005 QC
Unported Street-Strikers, Unported Intake, Headers, etc.
226/228 on a 115
11:1 on pump gas
600.3/598.2 Dynojet through the auto and cats.
I think it was 387 when I bought it brand new in 2005
600.3 divided by 505 cubic inch= 1.18 hp per cubic inch through the auto. Or 1.23 hp per cubic inch IF it was through a standard... But it isn't. :)
Past couple of tanks 19 Imperial miles per gallon.
So the engine seems to be efficient.
Im happy with that.
Nice numbers
Cam numbers above are wrong; should read 234/236 on a 115, .630"
The rest is all good. :)
Thanks!
Эвакуатор — данное созданный намеренно с целью транспортировки автотранспортных денег авто. Присутствие данном, применяется автоэвакуатор равно как с целью транспортировки призывающих ремонтных работ денег перемещения, таким образом также с целью новейших автомобиля.
<a href="https://24h-evakuator.ru/">https://24h-evakuator.ru/</a>
<a href="https://24h-evakuator.ru">Эвакуатор</a>
<a href="https://24h-evakuator.ru">Эвакуатор дешево</a>
<a href="https://evakuator-mag.ru/">https://evakuator-mag.ru/</a>
<a href="https://evakuator-mag.ru">Эвакуатор</a>
<a href="https://evakuator-mag.ru">Эвакуатор дешево</a>
<a href="https://ujhjl.ru/">https://ujhjl.ru/</a>
<a href="https://b-motion.ru/">https://b-motion.ru/</a>
Well, I don't know about my truck transporting money, but it has cost me quite a bit to get it to where it is now. :)
What I'm the world!!! Look at the text in the post Ronnie replied to
just up a post or two
