FSTJACK
I am having lower front control arms made in chromemolly. This will save over half the weight of the originals. Less unsprung weight will make the handling much better.
These are being made at Alpine CNC in Laguna Hills.
I purchased a pair of stockers to send to them to be digitized and have the new one's patterned.
They will all be jig built.
These will be made of chromemolly and will incorporate an adjustment in the rear so caster can be correctly adjusted. The adjustment will take out some of the twitchness that is inherent in the trucks. This will allow the king pin angle to be laid back giving much more stability at high speeds. They will mount in the stock location and take the stock spring and stock or replacement shock.
They will cost in the neighborhood of 500.00-600.00 per pair.
As we get more of them made the price will come down per pair.
Get in on this, as it will benefit the handling and reduce weight. The first run will probably be the best price.
These will fit 04-05 regular cabs and 05 quad cabs. They will not fit 06 trucks.
I will be starting a list for those want to get in on this. They will have to be paid for ($400.00 deposit) before they will be built.
We will need to get a new lower ball joint and bushings. I will look into the best quality and price on the joint and urethane bushings.
PM or call me, 619-444-2360 for any info.
