Guys, a while back I took my truck into a dodge dealership to diagnose a problem I was having and as usual my truck left the dealer with one more problem than what it went in for. My turn signals worked perfectly and also the hazards because I turned them on when the truck was towed in. The day I picked up my truck from the dealer I was on my way home and noticed that my turn driver turn signal was blinking rapidly. This was not and issue before I took it in. Well today I finally got around to checking to see if the bulb was blown and put in a new one. Bulb was fine, so I checked with a test light to see when the turn signal was activated if I had power, nothing again. I didn't blink when I put the probe into the connector so I tested the wire before the plug and no power going to connector. Looked in the fuse box to check to see if there was a turn signal fuse and only found parking light fuse. Mind you the parking light on that side works, but no fuse for turn signal. Does anyone else know what I can do or check? I remember there being an extended warranty on out turn signal switch because of some weird issue where you would put the driver turn signal on but the passenger side would blink and vise versa. Any help or input would be greatly appreciated. Looks like the dealer is trying to get some extra work!!!!!!! F'ed up!!!!!! Can't stand stealerships!!!! :/
