Built Engine, Good News!
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
First off lets get one thing straight, you removing the stock pistons and putting in forged ones does not constitute a BUILT engine...Your positive and encouraging words were pretty worthless with this said...Its obvious any fool can slap in some slugs, but the builds you are being positive and encouraging towards were actual builds and not just Cletus the slack jaw yoakal slapping in new pistons...
What a fucking debbie downer you are .
Why pull the engine when all of my cylinders were within factory specs for bore, taper, and out-of-round???
Ok, so the pan had to come off, right? The time you took to jack the motor up to get the pan off you could have had the motor out..Im sorry tho I just like to do things right...
I guess after you are a member here a full year you earn one of these?
because im calling bullshit on some stroke compairing his piston swap to the extensive work engine builders do???
WELL THEN I GUESS YOUR RIGHT AGAIN!!! Just be sure to let everyone else know I don't want anymore confusion....
Lets refer back to post #3 and I'll elaborate from there, my definition of a "built engine" as you seem to be lacking the intellect to do so.
Forged pistons(raised compression)/rods, cam, springs, pushrods, ATI balancer, port/polished intake, port matched heads.
From top to bottom:
Port/polished intake manifold
Mopar intake manifold gaskets
Comp cam valve springs
Comp cams pushrods
Comp cams XR 270 cam
Port match heads
Mopar gen IV head gaskets
Wiseco coated pistons
Wiseco file fit rings
Wiseco "floating" wrist pins w/spiral lox
K1 rods w/arp bolts
clevite coated bearings
ATI super dampner
Mopar front/rear crank seals
Mopar oil pan gasket
Ask around, this list is typically what you will find to be considered a "built engine".
Again, why pay for machine work when it is within FACTORY SPECS?
Lots of grumpy stuff.
I really think the moon cycle is effecting your mood. No worries though, you are not along. I've been extra sensitive for about a week and a half. I got so bad that I even bailed from my own timeslip thread.. Who does that? :confused:
I googled you. It's now in the mail. Mopar-or-no-car doesn't get his just yet. Maybe after we see some time slips and vids of these TRACTORS :D
That's strange... I don't feel anything? Shouldn't I feel something if I am "googled"?
Not trying to stir the pot but if one is going to do a in frame rebuild its really easy if you know for sure the bore is really in spec , the cross member that blocks the pan from coming off easy is an easy fix.
Get a demel cut-off bit and cut the small welds on it connecting it to frame
then unbolt it and BANG full access ,just make sure you drill a couple locating pin holes for easy alignment back to were it was .Then re-weld :D
From top to bottom:
Comp cams pushrods
Port match heads
K1 rods w/arp bolts
ATI super dampner
Someone got kinda quiet after this.
Beating a dead horse cartoon is coming up fast and furiously . :D
From top to bottom:
Comp cams pushrods
Port match heads
K1 rods w/arp bolts
ATI super dampner
Its obvious any fool can do as you did....Yes but a professional would have taken the time to remove the engine, and do it right..
