Automatic conversion parts
BLWNSRT
Member
Looking for auto conversion parts for an 06 let me know price. No trades
Transmission - may get local
Flexplate
Column and linkage
Brake pedal - may buy new
Center console piece - may buy new
Flexplate
Column and linkage
I am in the process of doing a 6 speed conversion. I have all the pieces you need off my 06 with 60K miles, except the center console bezel.
Alright as soon as you have everything together. send me a pm with price of what you got. I know I can get a core transmission for a good price and a buddy of mine builds my transmissions.
to the both of you !
Dont Forget the "underdash" harness from RC to QC !
Solves a lot of Problems in the electrics:D
That's right. I've heard about the reverse lights and other things not working because of that. Thanks for the reminder man.
I've got the wiring diagrams and pigtails to build a harness. Ive build a few before for customer cars and a couple of my own I've done. I'll create a conversion thread my goal is to be as close to OEM as possible and still have the ability to go back to the T56.
Let me know what you would like to then. My number is below.
Anyone have a picture and part number for the spacer between engine and transmission.?
Flexplate
Column and linkage
I have a trans also in my basement from an 05 Quad (Think they are alike)
I know 1st gear plates are shot and I may not be able to find the governor pressure sensor or solenoid (had a new one but sent to tuner to swap mine.)
No Torque converter also but I assume you are building based on the setup :). Lemme know if you need!
do you still need the spacers?
Still trying to find info, the pictures from the dealer do not show any spacer plate between the engine and transmission.
I have a new center console piece and a used brake pedal assembly so far.
I have everything if you need to go to auto, text me 6319603151 trans, plates, cooler, lines, flexplate
Do you need ECU for automatic. Have everything also parting out a 06QC.
Have trans and converter with 32000 miles B/O
