NukeGM/Ford
I knowJust seeing how many times we can get Scott to answer the question.
Hehehe
So the $3600 included wheels and tires? 20x10 front and 20x13 rear?
Found 345 22 tire can you widen the stock rears?
Is the overall diameter close to stock 22?? If not, does the stick trans have a toothed gear to switch out to correct speedo? ?
Chrysler tech can flash PCM for correction. They are 2 inches shorter. Lowers truck 1 inch
perreli scorpion 345 25 22
At 28" they'd be too short and only 13" wide. Still can't seem to find it in a 22", only a 20"?
I didn't see the tire listed that you're putting on those rear wheels
They're secret recipe
I need your address boss.
I was looking at the 13" rims can I just buy rear rims n tiers? N how much?
They're secret recipe![]()
