Its been kinda slow around here, so I thought I would post my current project (Planning phase)
I'm looking into, fabricating a set of traction bars. I was going to purchase the VR1 system until Scott broke the bad news to me, that he does not offer a solution for standard height quad cabs
. I have researched and selected all the necessary hardware. It is easy to understand why the VR1 system is priced slightly higher than the competition. Id like to hear from you guys that have built these systems for your trucks. The front bracket and bars will be pretty simple to do, Its the rear bracket I'm undecided on. A weld on bracket will be easier to fabricate and install. I found this bolt on rear bracket for the ford lightnings. It sits slightly inboard which puts the center lines of the mounting and frame rails more inline. Is there an advantage to a bolt on set, other than being able to return to stock? Are the axle tubes difficult to weld?
Also, what are your thoughts on the rear of the bars, being bushings, instead of the solid Heim joint, I've seen some options for poly bushings that still would be adjustable in length on the bars? Anybody having issues with their solid heim joints wearing out and rattling around, (Not that I would hear it)![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks
Kopack 05
Thanks
Kopack 05
