CYS
So i noticed there is a plastic piece on the inside of the hood but is only on one side (see image), my question is should there be one on another side? If so, does anyone what part # it is? Thanks.
![InkedIMG_6176_LI.jpg](/proxy.php?image=https%3A%2F%2Fhosting.photobucket.com%2Fimages%2Fi%2Fvgk79%2FInkedIMG_6176_LI.jpg%3Fwidth%3D450%26height%3D278%26fit%3Dbounds%26crop%3Dfill&hash=f0368d74c95b9c47c7092d5bb37bcbea)
I have one I took off of mine when I changed out the grill inserts, let me know if you'd like to purchaseinteresting, anyone the part # or where i might get one? I've search all over but no luck locating it. Thanks.
See attached, pretty good shape. Make me an offeris it in good condition? How much are you asking?
Looking at photos online they look very similar, but its up to youis the 05 the same as 06, because looking at the one you have for the driver side it seems like it looks different that what i have on mine.
What's the purpose of the blank outs, to direct the airflow into the engine comp better?The other side should be open for engine air.
Yes.
The passenger side has an opening/redirect "scoop" that directs outside air into the Airbox.
Hmm, I need to look at my truck, not sure if I have them.The panels are there for aerodynamics and primarily cooling. The passenger side directs air into the air box for the engine.
so i guess that might explain why my passenger side is missing, the person before installed a mopar intake with the cone air filter. Perhaps that part was removed to force more air into the intake? Just a thought.
Anyone know what part # they are? Would like to see if the 05 and 06 are the same or not
