- Joined
- May 18, 2006
- Messages
- 27,669
- Reaction score
- 5,111
Yes! Static working table lolLooks like they did good eye. Other ones I'm seeing have pistons to hold the tabletop. How about one that runs lol. Gotta be worth at least 10 k right?
I want a operational table hahaha ,,Yes! Static working table lol
Has anybody ever used these sockets to remove a rounded bolt ?
I thinking of trying them to remove a rounded tight ask lug nut . So tight it actually started and slightly bent my 4 way lug wrench !
I’m also trying to find the size of the trucks wings bolts and possibly using the same type of socket ,, the heads are rusted and have flaked to crap . No idea if metric or not !
If all else fails then I’m pulling out the C4 sucks that I’ll only ever have to use these socket sets or if I can get a single socket for 1 time ever use !
Sealey AK2747 13pc 1/4"Sq Drive Deep Lock-On Socket Set Rounded Nut Remover | eBay
Model No: AK2747. Fully polished mirror finish for resistance to corrosion. Features specially machined flutes in the walls of the socket which enable use on up to 85% rounded fasteners. Includes knurled ring for extra grip with oily fingers.www.ebay.com
https://www.ebay.com/itm/166622927961? itmmeta=01HTZ1RCFG4JK1BJ1K2G0ABQ33&hash=item26cb801c59:g:4QQAAOSwBUtl4NH~&itmprp=enc%3AAQAJAAAA4EI5%2BkyuPIphJUpWsfZs3d0mz9EfcQ2EgaKLe42IcFkTm5pmZQKRh0CSDI%2BCbIrN%2FZmx6Yc7IwiP%2BETD5m7VUH%2BJr9CsPgJs%2FQIPH553gnoQtu%2BRcCU%2FrUY%2FbBrgn6olrK0ZRbOB8hHnQHKAkNMJwbVPr%2FdhR%2Fg33xAYLWO3LujwEugNWa3wb4mdb944cp5EjX6X%2FHBbNc0BSeneexT6I9VA%2F4S6sxMc38H0Y2yRz94yoS25IBc2L19inTicG9aPsBRHZw5BY5ks0U2v5ztieV0lCNJQ7iNW%2BDxVotdC4fZf%7Ctkp%3ABFBM7sfh4ddj
Haven't used those. Have seen some with a bunch of pins in them. A 6 point socket hammered on usually does the trick with an impact wrench. I'm guessing the stud will pop if it's that tight. Anti seize new setup once you get it offHas anybody ever used these sockets to remove a rounded bolt ?
Heck c4 is faster that shipping hahahaI can't say if those (black ones) are the exact ones I used, but very similar and they did work.
C4 is always the LAST option!
Yes , about a 1/2 dozen times now hahaha .. but did you know that WD-40 is a healthy food included with one of Medicare advantage plans ! I was not denied on that purchase hahaha ,, yet they denied me for adding a Almond joy hahahaDid you soak it to the gills with WD-40 already?
I saw those , just not sure if there strong enough to get the lug nut off .. My impact gun is worthless for removing lug nuts hahaha , damn thing was only used a few times years ago . Still trying to find my breaker bar hahaha ! From what I’ve found out the socket need is a 17mm and it’s recommended the socket to use is an impact socket .Haven't used those. Have seen some with a bunch of pins in them. A 6 point socket hammered on usually does the trick with an impact wrench. I'm guessing the stud will pop if it's that tight. Anti seize new setup once you get it off
Yes the black and impact sockets seem to be recommended..I can't say if those (black ones) are the exact ones I used, but very similar and they did work.
Lol! Population control at its finestYes , about a 1/2 dozen times now hahaha .. but did you know that WD-40 is a healthy food included with one of Medicare advantage plans ! I was not denied on that purchase hahaha ,, yet they denied me for adding a Almond joy hahaha
I know .. the world has gone nuts ,, Now the insurance companies are trying to do people inLol! Population control at its finest
It's hard to fill in the blanks sometimes, with limited info via posts. I know where you were going with the battery. Voltage would drop a bit each time another start attempt was done.Not wanting to ho up ozy's thread I'm just curious about what affect an old or weak battery would have on the periodic start up issues he's having? He didn't say if she has a fresh battery but if she's been sitting could that hinder her starting first crank?
You have Instagram?"Follow me on Instagram for more useless tidbits of information!!!"
