02 Z06 520rwhp MN
MNSRT
Lakeville MN
Up for sale is my 2002 Electron Blue Z06. This Motor is a Tony Mamo built special - It was the first motor to showcase the AFR 215 cylinder heads and the motor was highlighted in the August 2010 edition of Popular Hotrodding. I have driven the car cross country just as it sits and it will get nearly 30MPG on the highway.. Chassis has 55,000 miles on it. Motor has 7000 miles on it. All other "mods' have less than 11,000 miles on them. RPM Quaife diff was just installed 1200 miles ago. Car was tuned by Mike Norris of Norris Motorsports in indiana, as it sits now the Car makes 520RWHP.
EXTERIOR
Electron Blue
Caravaggio rear spoiler
Stealth Cannon HID fixed headlights by forum member RadioFlyer
IForged Aero wheels. Brushed aluminum centers. F18x9.5 R19x11
Nitto INVO tires F275/35 R305/30 -- 70% tread left
LED switch back DRL's/turn signal lights
LED halo rear tail lights
INTERIOR
Ebony
Leather Corbeau racing seats
Seat heaters
HUD display
Seat and mirror memory
Dual climate control
Hurst shifter w/ LG delrin race knob
Entire interior was removed and sound deadening material was added
Pioneer Double din radio with blue tooth hands free control, navigation and I pod control
Back up camera
Aluminum gauge bezel rings
All interior lights switched over to led
Cyberdine steering wheel, glove box and door sill emblems
Alpine door speakers
Alpine 10" sub in "partition" sub box
Infinity amp (hidden in partition)
Laptrax controller
ENGINE - Built by Tony Mamo - 407 cubic inch
Dewitts radiator
Vararam power duct w/ big 'ole K&N filter
Meziere electric water pump
Racetronix intank fuel pump
Racetronix fuel pump wiring upgrade
Racetronix flow matched 42lb injectors
SpeedInc fuel rails
GMPP valve covers
FAST 92mm ported by Tony Mamo
Vmax ported LS2 TB
Mike Norris catch can on valley port
ATI Super Damper 10% underdrive
Brand new GM LS2 block w/ all new covers
Block bored to 4.022"
Callies Compstar crank w/ 2" pins, 4" stroke
Callies Compstar rods
Wiseco coated pistons w/5cc valve reliefs
AFR 215 cylinder heads ported by Tony Mamo
Yella Terra rocker arms -- properly set up by Tony Mamo
AFR 8019 valve springs -- properly shimmed by Tony Mamo
Crane billet lifters
Tony Mamo ported oil pump
ARP main studs
ARP head studs
Comp cam 232/232 114+2
Compression ratio is 11.7:1 -- runs on 93 octane.
EXHAUST
ARH 1 7/8" long tubes
ARH off road X-pipe -- car does NOT have catalytic converters
GHL Bullet cat back
DRIVELINE
RPS Carbon Twin Disk Lite clutch/flywheel
Tick Performance clutch master cylinder
Torque tube couplers replaced w/ stock units roughly 2000 miles ago
RPM Level IV tranny -- fresh fluid installed 750 miles ago
RPM Quaife Diff 3.90 micropolished gear set. 3-rib case. Installed 750 miles ago
Pfadt adjustable coilovers.
Crossdrilled and slotted rotors front and rear
I do not have any of the stock parts. Everything I have is on the car.
I will accept cash or certified check.
$30,000
Adam
612-382-6439
Untitled by adamthompson3104, on Flickr
Damn thats a nice C5. I would trade my truck for that, but your in MN.
I would give my left nut to have that car…Im sure you dont want that though. If you do let me know. Nice. Damn. Car… Let me play the lottery bro Imma hit you up.
other then being a chevy sweet car good luck with the sale
very nicely done:rock::rock::rock:
Thanks for all the comments guys, the car has been sold but it won't let me edit the first post.
