48RE Differences
sublimeswinger
Santa Clara, CA
Is there a difference in the 48re transmission in our trucks and the 48re diesel transmission? Or are they the same thing?
If you are asking if the 48RE from a diesel could be installed in our trucks as is and work properly, the answer is no.
There are (3) internal differences between the two units.
Can a 48RE from a diesel be made to work in an SRT-10? Yes (quite easily); and vice versa.
I think I need a new one. There is a small grinding at 10 mph, but then goes away. It also seems like its slipping 1-2.I may have a pinion angle issue, and I think my carrier bearing is bad. It sometimes does go into park , only makes it to reverse, even though the shifter is all the way
others have found that the linkage needed a slight adjustment, its on here somewhere
Lightningraper still has one out of the truck he is parting out. Hit him up
