Do I smell someone putting a Viper engine in a 1958 Plymoth? As long as the system is in good shape (new hoses¬hing rusted) I don't see a problem. The system will most likely be converted to R134A anyway seeing R12 was $600 a pound last time I checked.
would have to find an adaptor or a good a/c hose shop to hook up the lines to the compressor. goin from a high mount a/c compressor to a low mount, probably longer hoses.
don't forget to make sure whatever fan set up your goin to use for the condensor will kick in before the lines start to blow
