yellowfever#154
I need to add two switches, line lock and activation for my AMS-2000. I cant seem to find any switches that I like, what have you all done?
I've made a switchplate for our nitrous systems that discretely hides the your ashtray. Push ashtray door, it flips down exposing switches. Can close after for stock appearance..just an option you could use. Has two switches and a momentary switch used for purge setup but believe you can use thatvtype for a line lock as well.
Any chance you have any pictures of this installed?
Isn't that chime annoying as hell?
How about a button hidden in the shifter. You could use a second toggle switch in the ashtray to arm the button whenever you thought you might be using it and activate the line lock with the button.
https://www.hotrodhotline.com/hurst-shifters-nitro-stick
