Air Force Test Game
black pearl
Shake & Bake, CA
The object of the game is to move the red block around without getting hit by the blue blocks or touching the black walls.
If you can go longer than 30 seconds you are phenomenal:rock: It's been said that the US Air Force uses this for fighter pilots. They are expected to go for at least 2 minutes.
Give it a try but be careful...it is addictive!!
http://members.iinet.net.au/~pontipak/redsquare.html
That's cool. After 10 tries, I made it to 12.3 sec. I found if you tense up, your movements are not as fluid and you lose concentration/hand eye coordination.
18.531 seconds on second try.. I seemed to have stumbled onto a pattern that would promise a higher score. But it DOES speed up significantly by about 17 seconds in.
i found the pattern too...about 15-16 seconds jumps way up...
