Srt10650
- Joined
- Sep 30, 2016
- Messages
- 362
- Reaction score
- 311
WOW.. that is a lot of work! When can i bring mine over!
Very cool of you to lend a hand..
Whenever your in Cali, just give me a heads up. How’s the truck?
What did you use on the intake? Has anyone just blasted and clear powder coated theirs?
What does the larger governor pressure sensor do? How much for all the parts, and where did you buy them?48re was up next. The shop in Arizona had done a flush, which is definitely a no go. I looked/smelled the fluid and look/smelled old to me. I wouldn’t be surprised if they never even messed with it. Magnet was covered in metal shavings.Truck also had a stutter from 1-2 gear under light throttle. I dropped the pan, cleaned everything out, adjusted front/rear band to specs, replaced governor pressure sensor with a new bigger Borg Warner, replaced with a new transducer, new filter, new gasket, bolts torqued to specs and topped off with new mopar ATF.
You really hooked him up! Good job! Curious, why didn't you go with Amzoil for the engine and rear end? I want to add a Detroit Tru Track to the rear, and plan to use the Amzoil for the lube. I'm already running Amzoil in the engine.Everything was done over 3 weekends due parts and both of us having families and work. I appreciate him giving me a call and I’m glad I was able to help out. Really cool guy that I consider a friend now and a fellow viper owner!
Hey you are right. I don't have a virus so it must be right.Thank you so much brother. I’m so grateful for your help with the truck.
I got back from my 800 mile drive from AZ with the truck and went to take my lady out for a spin that that evening the damn thing wouldn’t start. Ughhhh hahah I became a member of a forum that night and started going through posts. Figured out the key trick to check the codes found that it was a crank position censor and o2 sensor codes I was getting. Was able to change the crank position censor but I’m not much of a mechanic. I searched all over the forum for trusted mechanics and had called around but no luck. The local dodge dealership wanted $225 to start tearing into it. It was a bit to rich for my blood, and luckily after hanging around the forum lurking and reading. I found @Srt10650 had just done a bunch of work tuning up a buddies vehicle and saw that he had mentioned that he was in the Bay Area. I messaged him and was on the phone with him and within a couple hours I had driven up to his house and dropped it off.
I’m so grateful that This community is around to support this truck. This is my dream truck and it’s been quite the month figuring all this stuff out!!! Wow hahah.
Thank you Salvador!!!! Your the man, and I got a homie for life!!!!
Vroooom vroooom. Now to go out and drive. (I heard our exhaust kills corona virus )
No, my rear works fine, but I have a bad wheel bearing. Since you have to pull the axle's to replace them, I thought about an upgrade. The Detroit can handle close to 1200 lb ft torque, and the slightest slip of a tire, it locks the other wheel.Good question. I just use it because it was the factory fill and I like Mobil 1. It’s really a personal preference, I know the SRT vehicles now run Pennziol from the factory. If you don’t mind me asking why upgrade to a Detroit Tru Trac? Is the factory limited slip differential not performing good enough?
Thanks for the tip!It increases the line pressure and also helps out with some of the issues the factory one tends to have. Like the stuttering, some of the gear searching under light throttle, and with the increase line pressure a little stiffer shifts(not as harsh as a shift kit though). Way better improvement over stock. I usually get my parts locally. They have them online, I would just search 48re Borg Warner solenoid kit. Comes with a new Borg Warner solenoid and a new transducer.
What's the valve cover torque spec, and is there a sequence, like tightening lug nuts on a rim?Next was to replace the valve cover gaskets which had been leaking and to clean up the valve covers from all the gunk/oil. Cleaned everything out, replaced with new gaskets and torqued to specs.
Yes, this is my issue. It "stutters" as if wanting to shift into second, but can't make up it's mind. The shift from second to third is real quick, don't remember it being that way when I first bought the truck last years.48re was up next. The shop in Arizona had done a flush, which is definitely a no go. I looked/smelled the fluid and look/smelled old to me. I wouldn’t be surprised if they never even messed with it. Magnet was covered in metal shavings.Truck also had a stutter from 1-2 gear under light throttle. I dropped the pan, cleaned everything out, adjusted front/rear band to specs, replaced governor pressure sensor with a new bigger Borg Warner, replaced with a new transducer, new filter, new gasket, bolts torqued to specs and topped off with new mopar ATF.
