OSO
I new i wasn't tripping over something in the garage.Ironhead said:if you need them cases back let me know i have them sitting in my office.
OSO said:Had my old one cut open cleaned and checked. This will be the third 727 to go in it. I have put less than 2000 miles on the motor because i cant keep a trans in it.
yellowfever#154 said:I had a local shop build me one for my Javelin. Its been a while so I forget all what was done exactly. There was different planetaries, clutchs, sprag, reverse manual shift body, hmm what else???? I dont remember, but it was about 2K I think to have it built. So far so good, but I dont have too many miles on it. Talk about hard shifts, it will bang gears so hard it damn nears breaks your neck.
Still using stock clutch drum with bolt in sprag with no low band apply so lets just hope it holds. If it makes it a few months of just driving and no 1/4 mile runs i will upgrade a few more parts . That will include the low band apply and a few lighter billet parts. Might be another grand or more but i can get close to dropping 8 lbs of rotating weight in the trans.mopower1958 said:Make sure you have a billet clutch drum in it so it does not explode if the sprague brakes. Bolt in sprague and billet drum are the essential torqueflite upgrades along with no first gear burnouts unless you have a low band apply valve body.
Cope is where im getting every thing now. First time trans failed sprag started to come apart but i think something else caused it i dont believe it was a hp issue.mopower1958 said:The stock drum is ok for regular street driving but it is made out of powdered metal and if the sprague fails the drum explodes and when it explodes it takes out the whole transmission assembly,floor pans and has broken some feet. If you go with a Griner trans brake be sure to use billet servos because his valve bodies run more pressure than anyone else and the factory servos will crack. A&A transmissions or Cope Racing Transmissions (CRT) can fix you up as they race what they sale.
You "thought" does that mean it didn't work???? I have a feeling i might just have to bite the bullet ans spend another 1500 on internals or give up.Begood said:I have a Cope billet drum in my Duster trans. I though it was cheap insurance.
Bill.
I think your looking at the planetary housing its welded together , thats my 475 dollar lower first and 2nd gear.Fahrenheit said:The input shaft looks like you have been putting some heat on it due to the discoloration.....is it suppose to be like that?
That makes two of us.Fahrenheit said:got ya....you can tell I know nothing about the inside of a transmission
If it last for a few months with no problems i will go back in and replace a few more of the high dollar items just to ease my mind. I just didn't want to test my trans capabilities with 2000-2500 dollars worth of billet internals. So if it last i will replace output shaft input shaft front drum and have the case machined for a bearing to support the over running clutch. Just money right :dontknow:.ZCx said:thats probably a good thang in this situation, James
:rock: :rock: :rock:
