As for tires . We all understand when the sit the dry rot … same with brains and then the zombies take over hahaha !
Tires are made using oil in the manufacturing process , some use more than others . I don’t know the % used , but was told Michelin use a high amount .. maybe that relates to the higher costs . More oil the longer it takes to dry out or dry rot is my guess .. I have zero idea of other manufacturer’s processes and oil % !
If you’re not going to drive at constant very high driving speeds .I see no need to have a tire rated at 150 mph or even occasional drag racing hahaha . You can’t constantly run high speeds on the streets , you will get busted before your tires blow out hahaha !
The more chamismo and keep up with the Jones doesn’t ever work for long as most will sooner or later break their bank using the cool factor BLING BLING ! I want my teeth all gold capped and look like Jaws in the James Bond movies hahaha ! They won’t make you go faster .
