shorty
Here is the new info on my heating problem. New radiator cap, added anti-freeze to overflow jug as the radiator was full. Remember that it always ran 1.5 inches low. Now it is at top. Drove about 50 miles and then got up to speed (80 mph---legal in Texas). The oil temp gauge and dash gage went to 200 so I turned off the air-conditioned and turned on the heater. Also dropped speed to 70 and the temp went down to about 195-198. Turned on the air and no rise in temp. Went back up to 80 and gauge went to 200. Pulled over and removed the cap----zero pressure. About 2 inches of fluid left the overflow and stuck my big finger in the radiator. Hot but did not burn. Drove another 180 miles and could run 80 without air or 70 with.
In the old days when you overheated and turned on the heater to cool the temp down that usually meant you had a reduced flow radiator. Is the only way to check the fan is leave it running while the truck is hot and take a peek? Is 200too hot for these trucks?
Baffled and do appreciate all the help. :dontknow::dontknow:
