Bleeding Fuel Injection System
sleepersrt10
Member
Middleburg, FL
This may be a dumb question, but is it necessary to bleed the fuel injection system after maintenance? I am replacing the injector O-rings.
I have a Sean Roe supercharger setup with the two fuel rails connected to each other via a fuel line in the front. I do not remember what the stock setup looked like.
I assume it is a self-bleeding system, but you know what happens when you assume...
