Heres how I rebuilt mine.
Separate caliper halves. Mark wich port is the bleeder & which is the crossover tube. Use a C-clamp and a block of wood wood against pistons. leave a small gap between piston and wood. apply low pressure shop air to inlet or crossover. make sure pistons start extending evenly.
If one piston pops out completely you'll play hell getting the other piston out.
release shop air give a little gap between piston & wood & reapply air. Repeat this process until both pistons are at the end of the bore.
DO NOT PRY OR ATTEMPT TO GRIP & PULL PISTONS They are composite and will chip crack break.
Once pistons are out R&R oring in the bore. lube orings and pistons with clean brake fluid. Press piston back into bore. Using C clamp and wood block you can coerce them back in. then reinstall outer dust seal.
Re-mate the halves and install the crossover tube & bleeder
