FaSt-RAM-716
got check engine light
p0432 and p0420 what could it be
it's 18mm x 1.5.......Prof said:Strapping the down stream sensors to the frame works on the '04's not sure about the others. You will have to buy bung plugs for a few dollars...(17mm I think I recall). Then clear your codes by rebooting the PCM (disconnect the negative terminal on your battery for a few minutes...then reconnect.)
what sims do you have now ? any ?FaSt-RAM-716 said:idk if the jmb catless mids have sims should i get the sims from roe?
you mean the welded in, threaded bungs ??FaSt-RAM-716 said:towers that came with mid piping that prof is talking about
FaSt-RAM-716 said:that could be the problem i got one leak ill fix that
I am looking at much the same work as you have. What was the RWHP when you where done? Do you think now that you have it, it was better than Paxton?TNVIPER said:P0420-1/1 CATALYTIC CONVERTER EFFICIENCY - SRT10
P0432-2/1 CATALYTIC CONVERTER EFFICIENCY - SRT10
RMoore said:I am looking at much the same work as you have. What was the RWHP when you where done? Do you think now that you have it, it was better than Paxton?
I am just starting to make mods to my truck. I have put on a Volant CAI, I dyno before and after. Beleive it or not I LOST 3 HP! Maybe because it didnt have a 100 head wind? Have you dyno with the header? If so what was it now with this set up?Halligan said:You are using mechanical sims, right?
