I thought I read somewhere that if you chrome engine parts it will make it retain more heat. Is this true?
MoparMan84 said:I wanted to have my intake manifold chromed or polished to a mirror finish.
show offFSTJACK said:The polished or chromed intakes look good for sure.
The situation with "heat soak" would come into play after you shut down the motor and let it sit for 5-10 minutes.
"Heat soak" will be worse with a polished or chromed manifold.
Unless you are going after big HP I would not worry about heat soak.
The computer will pull a lot of timing when it senses hot intake air temperatures.
I personally would not worry about heat soak and just go for the look you want.
I am running a modified stock style intake on the red truck and I had it powder coated by JMB Justin.
I did not want the upkeep of polished and did want to pay for chrome.
There is the spray on coating that Edelbrock uses and calls it Endura Shine.
It is in my opinion a good look and there are several places that can do this type of finish.
I am putting up a pics of the powder coating that JMB did on my parts .
MoparMan84 said:What color of powdercoat is your manifold? I like the look of that!!
VIPER said:
MoparMan84 said:Anyone know where I can get a Gen III intake manifold for a decent price? Contacted X2 builders and they quoted me $750. Also, would I gain anything from porting and polishing the inside of the manifold?
Ironhead said:does that thingy run or is it just for looking at :aetsch: :aetsch: :fisheye:
