CLUNKS WHEN COLD ABOUT EVERY MINUTE WHEN COLD
KINGSNAKE
I USE CAPS BECAUSE I'M HEARING IMPAIRED
SOMEWHERE IN LOS ANGELES
KINDA SOUNDS LIKE ITS A MOTOR MOUNT CLUNK BUT I CANT PIN POINT IT. IS THIS NORMAL? SEEMS TO STOP WHEN WARM ITS SOMEWHAT ANNOYING BUT IT DOES NOT AFFECT DRIVING AT ALL
WHAT NUT ARE YOU REFERING TO? IT DOES THE NOISE WHEN TRUCK IS PARKED
I know you're looking for help, ignor arch, he's an idiot trouble maker
Never ignor engine bay clunks, pick up the phone and call one of our vendors
These trucks have a normal knock/clunk, from the exhaust manifold. After it's warm, shut the truck off and see if it does it, as it's cooling down
Sent from my SAMSUNG-SM-N910A using Tapatalk
Do you have a video of it? Before I changed to my belangers I had a clunk type noise that would start from a cold start and go away when warm and also after shutting off as the engine was cooling down. Turned out the heat shield on the pass side had a Crack on either side of the manifold which I suspected before the header install.uploadfromtaptalk1469929412776.jpg
Sent from my SM-G935T using Tapatalk
Thanks fellas
I was starting to think the same thing about the manifolds. Thanks fellas I'm pretty positive that is the noise I am hearing.
